Is is possible to adjust the flowrate ?
Posted: Tue Dec 02, 2014 1:57 am
by gelly
Is there an option to adjust the flow rate (mm/sec) in simplify 3D? if so, where ?
Re: Is is possible to adjust the flowrate ?
Posted: Tue Dec 02, 2014 8:26 am
by dennisjm
This is your extrusion multiplier on your extruder tab. In S3D it's an actual multiplier of the actual filament amount, e.g., .9 makes 10% less filament come out than 1.0.
If you're printing via USB, there is a flow rate knob on the printer control panel that you can use to adjust the flow rate in real time.
Posted: Tue Dec 02, 2014 10:38 am
by KeyboardWarrior
The USB knob only works with RepRap printers. I believe MakerBot/Sailfish doesn't support it.
Posted: Tue Dec 02, 2014 10:27 pm
by gelly
thanks, i will try different numbers to see what the impact is
Posted: Wed Dec 03, 2014 8:24 am
by dennisjm
One thing I've done when calibrating is to just make about 5 different cubes on the same print and assign each one it's one process. Then each process just change the multiplier so you end up with .9, .92, .94, .96,.98 or something like that. Then you can see which is best and you don't have to restart the print 5 times.
Posted: Sun Jul 26, 2015 9:56 am
by Narg
This is where I think S3D doesn't live up to it's name. Why not just call it "flow rate multiplier". Sure that name is technically not correct, but it would simplify the process tremendously, rather than forcing users to come to the forums for answers.
