build stats in cm3
Posted: Tue Dec 02, 2014 1:26 pm
by Johnsaen
Coul you also give a stat of cm3 used since hubs calculate in cm3, shouldn't be so difficult?
Re: build stats in cm3
Posted: Wed Dec 03, 2014 9:26 am
by jimc
not sure if this is what your looking for but on the top, goto mesh then calculate volume. if gives you the cm3 of the model.
Posted: Wed Dec 03, 2014 11:16 am
by KeyboardWarrior
jimc wrote:not sure if this is what your looking for but on the top, goto mesh then calculate volume. if gives you the cm3 of the model.
I believe he's asking for cm3 if filament used. Which since the filament diameter is calculated, as well as mm of filament used, would simply be multiplying those two by 3.14 and you'd have mm^3 or the volume of filament used, which is easily convertible to cm^3.
Posted: Wed Dec 03, 2014 9:42 pm
by TenKOhms
correct me if I'm wrong, but I believe this calculation is missing a couple steps and will only yield mm^2
pi * r^2 * h = volume of a cylinder ; the length of plastic used is the height, you forgot we have diameter of filament not radius
so I believe the proper formula will be:
