Page 1 of 2
[FIXED] Incorrect Slicing in V5.0
Posted: Mon Jan 16, 2023 5:47 am
by PatrickLevesque
With V 5.0, all my slices are wrong !
They are all correct with V 4.1.2
I'm waiting for an update ! For me the V 5.0 is unusable.
Re: Incorrect Slicing in V5.0
Posted: Mon Jan 16, 2023 10:33 am
by S3D-Jason
Can you post the STL file that you are trying to slice? If you go to the Repair menu and search for non-manifold or self-intersecting surfaces, does it find any errors with the mesh?
Posted: Mon Jan 16, 2023 11:34 am
by PatrickLevesque
No error !
And it is OK in V 4.1.2, for all my STL !
Posted: Wed Jan 18, 2023 3:29 pm
by PatrickLevesque
I just installed V 5.0.1 and the results are even worse than with V5 !
I have to work with V 4.1.2 ! V 5 is unusable for me.
Posted: Wed Jan 18, 2023 8:36 pm
by wirlybird
What is the printer?
Posted: Thu Jan 19, 2023 2:11 am
by PatrickLevesque
Creality CR-X
What is curious is that everything works correctly with V 4.1.2 !
Posted: Thu Jan 19, 2023 7:39 am
by wirlybird
I just loaded that printer into v5 and sliced a few files without making any changes and they looked ok.
Maybe try to delete that profile and reload it from scratch to see if it helps.
Otherwise go through settings to see what might be an issue or what might have been changed.
Posted: Thu Jan 19, 2023 7:56 am
by PatrickLevesque
Nothing to do with the profile...
With any profile or printer, it's the same !
It works in V 4.1.2...
Posted: Thu Jan 19, 2023 8:08 am
by wirlybird
can you point out in the picture the specific issues?
I just put your STL in to Netfabb and it has issues. 76 shells. This is likely at least one problem.
Posted: Thu Jan 19, 2023 8:33 am
by PatrickLevesque
I don't care about NetFabb...
I paid for an update that doesn't work !
All my files work in V 4.1.2 and other free slicers... Not in V5.0.1 !
