PatrickLevesque
[FIXED] Incorrect Slicing in V5.0
With V 5.0, all my slices are wrong !
They are all correct with V 4.1.2
I'm waiting for an update ! For me the V 5.0 is unusable.
Re: Incorrect Slicing in V5.0
Can you post the STL file that you are trying to slice? If you go to the Repair menu and search for non-manifold or self-intersecting surfaces, does it find any errors with the mesh?
PatrickLevesque
No error !
And it is OK in V 4.1.2, for all my STL !
QRC_JAF_Bisous.STL
(215.32 KiB) Downloaded 257 times
PatrickLevesque
I just installed V 5.0.1 and the results are even worse than with V5 !
I have to work with V 4.1.2 ! V 5 is unusable for me.
What is the printer?
PatrickLevesque
Creality CR-X
What is curious is that everything works correctly with V 4.1.2 !
I just loaded that printer into v5 and sliced a few files without making any changes and they looked ok.
Maybe try to delete that profile and reload it from scratch to see if it helps.
Otherwise go through settings to see what might be an issue or what might have been changed.
PatrickLevesque
Nothing to do with the profile...
With any profile or printer, it's the same !
It works in V 4.1.2...
can you point out in the picture the specific issues?
I just put your STL in to Netfabb and it has issues. 76 shells. This is likely at least one problem.
PatrickLevesque
I don't care about NetFabb...
I paid for an update that doesn't work !
All my files work in V 4.1.2 and other free slicers... Not in V5.0.1 !
