Page 1 of 2
Infill Type Question.
Posted: Thu Feb 16, 2023 5:37 pm
by wirlybird
Doing a large part, 300X200X100, basically it is like a large rectangular box.
I am wondering what infill pattern will be the least likely to exert pulling forces on the sides and ends of the box while it is cooling and contracting. These forces tend to aggravate any lifting or warping of the bottom outer edges off the build plate.
The part has to be printed with a fairly high infill percent per customer directions.
Re: Infill Type Question.
Posted: Thu Feb 16, 2023 10:33 pm
by arhi
gyroid is great for this because the "lines" are "wavy" and not straight so the lines will straighten a bit while cooling rather than pull the edges inwards. having extra walls will help too. cuboid is faster to print but pulls on the walls much more as lines are straight
Posted: Fri Feb 17, 2023 6:21 am
by jfkansas
I'd try wiggle rotated 45 degrees, see pic. If the infill shrinks the pattern should stretch out instead of pulling sides in.
Sinusoidal would be similar as the "tubes" should deform before distorting the outer shell.
Use 3-4 shells also, the stiffer the walls the less likely they are going to distort. Can also play with infill ext width and percent. Lower infill ext width to around 75% and adjust percentage of infill to get the amount you want. This should make the infill walls thinner than the shell walls and be more flexible. Decreasing infill ext width should make the infill more dense so might have to lower infill % some.
For the most part just avoid infill styles that directly connect opposite sides with a solid straight line.
Posted: Fri Feb 17, 2023 8:04 am
by wirlybird
Thanks,
I'd like to try a few of these infills but I can't get V501 to slice them. It crashes!
I have another post covering that topic.
Posted: Fri Feb 17, 2023 12:46 pm
by jfkansas
Did you post the model file? or can you?
Posted: Fri Feb 17, 2023 3:26 pm
by wirlybird
Here is a factory test file. The part is a representation of the actual part.
Posted: Fri Feb 17, 2023 3:40 pm
by wirlybird
If I scale the part to 75% and use 50% Gyroid infill this is what I get. No image even though it seems to slice.
Anything higher on infill and it just shuts S3D down.
Posted: Fri Feb 17, 2023 6:19 pm
by DrD
wirlybird wrote: ↑Fri Feb 17, 2023 3:40 pm If I scale the part to 75% and use 50% Gyroid infill this is what I get. No image even though it seems to slice.
Have you tried changing S3D's Graphics Acceleration Mode options?
D.
Posted: Fri Feb 17, 2023 7:10 pm
by wirlybird
No, I have not looked at that. Thanks for point it out.
Posted: Fri Feb 17, 2023 7:28 pm
by wirlybird
DrD wrote: ↑Fri Feb 17, 2023 6:19 pm
D.
Just tried all three modes and it made no difference. Thanks for the suggestion though.
