Corrupt gcode over wifi for version 5.0.2
Posted: Sun Mar 12, 2023 2:10 pm
I've reported a problem to support but have not gotten a resolution. I was wondering if anyone else is experiencing this error.
I've tried to print two separate models over wifi to my connected Qidi X-Pro printer. I run an Eero wifi mesh network. The printer is about 6 feet from the router. On both occasions, the printer errors out with:
and
The models print correctly if I save them to usb and insert into the printer to print.
Has anyone had similar issues? Have you resolved them?
Illegal gcode in line:xxxx, P_4, T_10470103!Code: Select all
Illegal gcode n line: xxxx, P_4, T_10470000!Has anyone had similar issues? Have you resolved them?
