[Solved] First layer height not match with Simplify3D V5 selection ?
Posted: Sun Apr 02, 2023 6:03 am
Bonjour,
Question about the first print layer in Simplify3D V5 :
With my printer (Raise3D Pro2) ,the leveling of the plate must be done with a wedge or a sheet of paper at 0.2 mm : this is the 0 position of the printer.
I want a first layer of 0.15 mm in height and it' ok in Simplify GCODE (please see attached images)
My question is :
in fact my first layer is at a height of 0.2+0.15= 0.35 mm !!?
I set the print bed closest to 0 instead of 0.2 and the first layer print was successful
Is it normal ?
Whith my old Flashforge printer, Simplify4 and same bed levelling (0.2 mm) Everything seemed to work
Thank you
My question is :
Is it normal ?
Thank you
