[Craftbot Flow IDEX] Fan speed (M106) Using "P" Not "T"
Posted: Wed May 17, 2023 5:31 pm
by JonS
I'm using 5.1 with my Craftbot Flow IDEX. It's generating M106 fan speed codes with "P" to index the tool, while the Craftbot using "T" (T0/T1).
How can I resolve this? Can the post processing scripts be used to replace strings?
p.s. I didn't have this issue when I was using 4.1
Re: [Craftbot Flow IDEX] Fan speed (M106) Using "P" Not "T"
Posted: Thu May 18, 2023 12:57 pm
by S3D-Jason
There's already a few threads about this on the forum if you search for it. Here's one that had a post-processing command you could use:
viewtopic.php?p=63519#p63519
Posted: Fri May 19, 2023 3:02 am
by JonS
S3D-Jason wrote: ↑Thu May 18, 2023 12:57 pm There's already a few threads about this on the forum if you search for it. Here's one that had a post-processing command you could use:
Thank you for the reply and pointer. My attempt at a search was a failure, so I'm not sure I would have found this.
