30 Characters
Posted: Tue Jan 20, 2015 9:35 am
by Umpa
Why can't I export my .stl to memory card with a 25 Character name ? thats 25 characters plus 4 for the extension, thats obviously only 29 all told. When I try I get an error telling me to use less than 30. What gives ?? is it some limitation of the GPX Plugin ?
Re: 30 Characters
Posted: Tue Jan 20, 2015 2:02 pm
by TenKOhms
the firmware will only read so many characters, and the converter is counting .gcode (input) as characters
Re: 30 Characters
Posted: Sun Feb 01, 2015 2:44 pm
by Umpa
If its counting .gcode is there a way to NOT output .gcode as I only need .x3g
Re: 30 Characters
Posted: Sun Feb 01, 2015 11:13 pm
by BaudR8
Umpa wrote:If its counting .gcode is there a way to NOT output .gcode as I only need .x3g
I think .gcode is defaulted, and could be possible (not 100% sure) gpx expects an input file with the extension .gcode, you could always rename the final .x3g file to whatever you want afterwards. But is it really necessary to reach the limit of characters the firmware can read?
Re: 30 Characters
Posted: Sat Mar 14, 2015 1:33 pm
by Umpa
Yes because I have the same object with different slicing profiles and its advantageous to be descriptive of that in the file name. As is I have to have my files in directories in order to portray the information required.
Never mind it is what it is.
