Single outline prints
Posted: Sun Mar 01, 2015 11:50 am
I'm trying to print a part with a 0,6 mm wall (airfoil). My Nozzle is 0,5 mm and the extrusion width is set to 0,6 mm. To get Simplify to print this part I already increased the Wall-Thickness to 0,7 mm, otherwise I get holes in the print.
The problem is now: Simplify is not doing only one turn each layer, but two. One clockwise, the other one counter-clockwise. Each one on the same path and with the same filament length extruded. So basically each layer is printed twice. This results in a doubled print time, doubled weigth, over extruded walls and a blob building up where the extruder changes direction from CW to CCW.
Is this a bug or did I just miss the correct check-box? (I don't want to use the vase-mode because I need a solid bottom layer)
