CubeX
Posted: Sat Jun 29, 2013 11:38 am
Could someone please explain how you use this software with a CubeX.
Thanks.
Thanks.
Hi, im currently using Kisslicer to print with my CubeX Trio, im looking for a software that will let me print with the three extruders.Simplify3D wrote:I'm attaching a .fff file that another customer was using with their CubeX. We don't have one in-house, so please use this with caution. You would also need to go to Tools > Firmware Configuration and select the included CubeX Firmware profile.
After those changes, Creator should be producing the correct G-Code for that machine. I know you can also load G-Code into the default CubeX software if you want to validate it that way, but you should be good to try it out on the machine after that.
