Movement Extrusion Override Settings are directly applied
Posted: Tue Mar 17, 2015 9:40 am
Hi!
When I print and use the Override Boxes to enter a new value for Movement or Extrusion override, every value gets directly submitted.
So when i enter 100 (via keyboard) first 1 then 10 then 100 is send to the printer.
The bad thing is when the printer is on a long path and receives the 1% movement overide.
Better would be only to send out the command when changing focus and/or when hitting enter (better both)
