Corners not filling.in
Posted: Tue Nov 07, 2023 9:24 am
by Todd_R
What do I need to change to get these corners to fill in? I have changed the extrusion multiplier to 1 and automatic. regular PLA .4mm dia.
Re: Corners not filling.in
Posted: Tue Nov 07, 2023 12:10 pm
by parallyze
Todd_R wrote: ↑Tue Nov 07, 2023 9:24 am What do I need to change to get these corners to fill in? I have changed the extrusion multiplier to 1 and automatic. regular PLA .4mm dia.
You might want to check the preview and pay attention to the retracts and/or starting positions. The picture does look like bad
retracts, missing material after each travel move:
It's likely the same cause for the messy perimeters and missing corners of the infill pattern.
Posted: Tue Nov 07, 2023 2:40 pm
by S3D-Jason
Could also check and make sure settings like coasting aren't responsible for those gaps (that intentionally turns off the extruder before the end of each path).
Posted: Wed Nov 08, 2023 9:20 am
by Todd_R
I did have the coasting on, so I'll try it with it off
