Todd_R
Corners not filling.in
What do I need to change to get these corners to fill in? I have changed the extrusion multiplier to 1 and automatic. regular PLA .4mm dia.
parallyze
Re: Corners not filling.in
Todd_R wrote: ↑Tue Nov 07, 2023 9:24 am What do I need to change to get these corners to fill in? I have changed the extrusion multiplier to 1 and automatic. regular PLA .4mm dia.
You might want to check the preview and pay attention to the retracts and/or starting positions. The picture does look like bad
retracts, missing material after each travel move:
It's likely the same cause for the messy perimeters and missing corners of the infill pattern.
Could also check and make sure settings like coasting aren't responsible for those gaps (that intentionally turns off the extruder before the end of each path).
Todd_R
I did have the coasting on, so I'll try it with it off
