Where Is My Ooze Shield?
Posted: Tue Nov 21, 2023 12:26 pm
by nfol
Why does the attached factory file not produce an ooze shield at all?
I had the same with prime pillar.
Best regards,
Niels
FlashForge Dreamer
Re: Where Is My Ooze Shield?
Posted: Tue Nov 21, 2023 4:24 pm
by S3D-Jason
If you change the preview coloring to "Active Toolhead", you can see that it only uses 1 tool for the entire print. That means there's no need for a tool change. If you go to Edit Process Settings > Additions tab > you have the "Auto-Stop Ooze Shield" option enabled, which means it won't add an ooze shield if it isn't needed.
Short answer - disable the "auto stop ooze shield" option or use a print that actually requires multiple tools
