The scale for MVS is from 0 to 96 on my version5
Posted: Thu Dec 14, 2023 2:00 pm
by myprinter
It can not be used if the scale so high. Think more normal will be 0-25mm3/sec
I set MVS in speed tab to 11mm3/sec and the scale have not changed.
Re: The scale for MVS is from 0 to 96 on my version5
Posted: Thu Dec 14, 2023 2:47 pm
by parallyze
myprinter wrote: ↑Thu Dec 14, 2023 2:00 pm The scale for MVS is from 0 to 96 on my version5
Are there any purges/extrusions inside the starting script which might explain the 96.3mm³?
Posted: Thu Dec 14, 2023 4:02 pm
by myprinter
No. Do you not having the same problem?
Posted: Thu Dec 14, 2023 5:09 pm
by parallyze
myprinter wrote: ↑Thu Dec 14, 2023 4:02 pm No.
So the first extrusion happening on a print is the skirt feature, without any purge/extruder moves happening before?
No.
Posted: Fri Dec 15, 2023 2:41 am
by myprinter
Problem is retraction, one more bug in v5. If disable retraction the scale is normal, when enabled the scale is wrong.
Posted: Fri Dec 15, 2023 7:07 am
by myprinter
It is the Wipe Nozzle bit there make the problems. When disabling it all is nice.
