Page 1 of 2
Why does this happen?
Posted: Sun Mar 22, 2015 2:33 am
by sarge5020
Any ideas why this happens? I'm printed this in ABS at 230 degrees C with a bed temperature of 110 degrees C sliced at .1mm.
Re: Why does this happen?
Posted: Tue Mar 24, 2015 11:56 am
by sarge5020
I had similar results printing with Bronzefil. Here are the two models
http://www.thingiverse.com/thing:738561 and
http://www.thingiverse.com/thing:715111 Maybe someone can have a look and see if there is some issue with the models. I run them through Netfabb before printing.
Cheers,
John
Posted: Tue Mar 24, 2015 2:50 pm
by DarthRevan
Could you attach your factory file so I can look at what might be causing this?
Posted: Tue Mar 24, 2015 3:32 pm
by sarge5020
Forgive me but how do I do that?
Posted: Tue Mar 24, 2015 5:30 pm
by bot
My guess is one of or a combination of two things:
1) too small layer height relative to nozzle size.
2) too low resolution on your extruder stepper driver axis.
Posted: Wed Mar 25, 2015 8:16 am
by DarthRevan
sarge5020 wrote:Forgive me but how do I do that?
Posted: Wed Mar 25, 2015 10:37 am
by sarge5020
Thanks. here is the factory file for a model printed with Bronzefil with the same results. I'll post a photo of those prints a little later.
Posted: Wed Mar 25, 2015 10:46 am
by sarge5020
Here is the model printed in bronzefil. Different material, same results.
Posted: Wed Mar 25, 2015 11:14 am
by DarthRevan
You should be fine with those settings. Perhaps your machine needs to be recalibrated. As bronzefill is one of the pricier materials I'd try printing some calibration prints in PLA. You definitely want the settings perfect when using <= .1mm layer height, as the margin for errors is much more noticeable the more detail you aim to have.
Posted: Wed Mar 25, 2015 11:19 am
by sarge5020
Would you suggest .2mm layers?
