Ironing will proceed before top layer if Top Layer Extrusion Modifier is 100%.
Posted: Sun Jun 02, 2024 5:32 am
by chiu
S3D should do ironing after top layer is done.
But I just found ironing will proceed BEFORE top layer if Top Layer Extrusion Modifier is 100%.
It will only work normally If Top Layer Extrusion Modifier is not 100%.
is this normal?
Re: Ironing will proceed before top layer if Top Layer Extrusion Modifier is 100%.
Posted: Mon Jun 03, 2024 9:53 am
by S3D-Taylor
Hi, I would like to help diagnose the cause of this. Can you attach a factory file that has the issue and one that doesn't?
Posted: Tue Jun 04, 2024 4:39 am
by chiu
S3D-Taylor wrote: ↑Mon Jun 03, 2024 9:53 am
I already attached both good and NG factory file for your reference.
By the way, we really need the checkbox to select model as below, please bring it back from v4.
- s3d v4 select model.png (12.74 KiB) Viewed 5717 times
Posted: Wed Jun 05, 2024 1:56 pm
by S3D-Taylor
Thank you for reporting this, I've replicated the issue and forwarded the files for the dev team to investigate. For now, you can work around by:
- Changing the Top Layer Extrusion Modifier to a non 100% value, which is your current fix
OR
- Changing the Solid Infill Speed to be different than the Top Layer Speed.
I have also forwarded a feature request to the development team to bring the model visibility checkboxes back.
Posted: Thu Jun 06, 2024 4:36 am
by chiu
OK, got it ! Thank you~
