chiu
Ironing will proceed before top layer if Top Layer Extrusion Modifier is 100%.
S3D should do ironing after top layer is done.
But I just found ironing will proceed BEFORE top layer if Top Layer Extrusion Modifier is 100%.
It will only work normally If Top Layer Extrusion Modifier is not 100%.
is this normal?
S3D-Taylor
Re: Ironing will proceed before top layer if Top Layer Extrusion Modifier is 100%.
Hi, I would like to help diagnose the cause of this. Can you attach a factory file that has the issue and one that doesn't?
chiu
S3D-Taylor wrote: ↑Mon Jun 03, 2024 9:53 am Hi, I would like to help diagnose the cause of this. Can you attach a factory file that has the issue and one that doesn't?
I already attached both good and NG factory file for your reference.
By the way, we really need the checkbox to select model as below, please bring it back from v4.
s3d v4 select model.png (12.74 KiB) Viewed 5768 times
S3D iron before top layer.factory
(11.5 KiB) Downloaded 372 times
S3D iron after top layer.factory
(11.5 KiB) Downloaded 419 times
S3D-Taylor
Thank you for reporting this, I've replicated the issue and forwarded the files for the dev team to investigate. For now, you can work around by:
- Changing the Top Layer Extrusion Modifier to a non 100% value, which is your current fix
OR
- Changing the Solid Infill Speed to be different than the Top Layer Speed.
I have also forwarded a feature request to the development team to bring the model visibility checkboxes back.
