Processes temps resetting.
Posted: Thu Mar 26, 2015 10:11 pm
by RonnieBlaze
Every time i open the software my extruder temp is reset to 200 and my bed temp is 0.
any one know why this is happening?
Re: Processes temps resetting.
Posted: Fri Mar 27, 2015 5:27 am
by JoeJ
Do you have saving enabled? for example, if you import a model and then close and reopen the software, is that model automatically loaded again?
Posted: Sat Mar 28, 2015 6:35 am
by MikaMa
All my settings reset also everytime..
Last model loaded is loaded again but all tweaks to settings is lost :/
Posted: Sat Mar 28, 2015 7:27 am
by JoeJ
First, go to Tools --> options, and make sure that "Save and restore application state" is enabled.
If the models and processes that you create still aren't restoring, then you likely have a permissions issue. You could try right-clicking and choosing Run As Admin to see if that makes any difference. You may also want to try deleting the temporary files that S3D creates. For Windows users, I believe you just delete everything in the C:\Users\<your user name>\AppData\Local\Simplify3D\Creator folder.
Posted: Sat Mar 28, 2015 7:34 am
by MikaMa
Thanks Joe :) I'm pretty sure this is a user error ;) Will check the settings
Posted: Wed Apr 01, 2015 2:56 pm
by RonnieBlaze
Sorry for the delay..
Joe, if i close the app with a model it will reopen the model.
What i did find out in the mean time was this.
I made 3 new process, for different layer heights, and i exported them out to .fff files.
now when i close and reopen the app the 3 process all have the correct settings saved.
but there is the default process1 if i remove it, it comes back every time. and my guess is that is default for my printer and the app keeps putting it back .
