RonnieBlaze
Processes temps resetting.
Every time i open the software my extruder temp is reset to 200 and my bed temp is 0.
any one know why this is happening?
Re: Processes temps resetting.
Do you have saving enabled? for example, if you import a model and then close and reopen the software, is that model automatically loaded again?
MikaMa
All my settings reset also everytime..
Last model loaded is loaded again but all tweaks to settings is lost :/
First, go to Tools --> options, and make sure that "Save and restore application state" is enabled.
If the models and processes that you create still aren't restoring, then you likely have a permissions issue. You could try right-clicking and choosing Run As Admin to see if that makes any difference. You may also want to try deleting the temporary files that S3D creates. For Windows users, I believe you just delete everything in the C:\Users\<your user name>\AppData\Local\Simplify3D\Creator folder.
MikaMa
Thanks Joe :) I'm pretty sure this is a user error ;) Will check the settings
RonnieBlaze
Sorry for the delay..
Joe, if i close the app with a model it will reopen the model.
What i did find out in the mean time was this.
I made 3 new process, for different layer heights, and i exported them out to .fff files.
now when i close and reopen the app the 3 process all have the correct settings saved.
but there is the default process1 if i remove it, it comes back every time. and my guess is that is default for my printer and the app keeps putting it back .
