Didn't print raft
Posted: Sun Mar 29, 2015 11:31 am
by horst.w
Hi @ all.
I have to print out an objekt with skirt, raft and support.
The preview mode shows all as well but the gcode begins without skirt/raft at a high of Z = 1.65 mm
I have no idea what happens.
Attachments - 3 pcs and factory-file
Horst, GER
Re: Didn't print raft
Posted: Sun Mar 29, 2015 8:14 pm
by TenKOhms
attach the actual g-code and factory file for people to take a look through
Posted: Mon Mar 30, 2015 12:10 pm
by horst.w
horst.w wrote:Hi @ all.
I had attached the facrory-file but where is it ???
A new one here from this object, but it is not the same (SD formatted after writing to this forum)! Now the gcode shows for layer 1 Z = 0.6.
I would say, when Z = 1.65 is a fault and prints in plein air, then Z = 0.6 is also a fault. I can't test it because I'm not at home (next thuesday), but the the max distance my Mankati can print is 0.4 mm.
Distance bed / nozzle = .15 mm, layer high = 0.15 and FirstLayer 80% = 0.12 ; total 0.27 mm
H.
Posted: Tue Mar 31, 2015 4:44 pm
by horst.w
Problem is nearly solved !!!
I have found out what is causing the fault, but not the reason why S3D has such a reaction and doesn't print the raft.
It is a drawn rectangle in the workplane-level outside the object. But it is not a surface, it has no height or depth and no capacity. I can not tag it and therefore I can not delete it. And I can not see it in the normal volume-mode, only in the grid-mode of ViaCAD. Only copying the main object in a new workplane had solved this problem.
Why S3D does not perceive this alien-objekt when in repair-mode or in preview-mode but does not print the raft instead I have still no idea.
Posted: Tue Mar 31, 2015 6:19 pm
by jimc
bad models cause all kinds of unexpected results. s3d has to have a good, watertight model.
