Il y a des manques / some missing information
Posted: Sun Feb 15, 2026 4:39 am
by PatrickLevesque
Bonjour,
J'ai un fichier pour lequel il y a des manques.
Sur cette photo, on voit qu'il manque une dizaine de lignes...
Il y a plusieures zones comme celle-ci sur ce fichier, même sur la dernière couche.
Pourtant, le fichier gcode semble OK.
Hello,
I have a file with some missing information.
In this image, you can see that about ten lines are missing...
There are several areas like this in the file, even on the last layer.
However, the gcode file seems to be OK.
AAA.factory
(210.47 KiB) Downloaded 7753 times
AAA.gcode
(1.76 MiB) Downloaded 8319 times
Re: Il y a des manques / some missing information
Posted: Mon Feb 23, 2026 7:09 pm
by KarlW1000
Looks like a bug in the software.
I tried a lot of different settings so the results were somewhat close to original. After slicing, the file looks good in simplify3d but I exported the Gcode file and imported it into Repetier Host and you can clearly see that it will not print correctly. It looks just like your picture.
Rotating the part
Scaling the part
Different nozzle diameters
Repair triangles
More/Less outline perimeters
Layer heights
Infill percentage
Mesh repair
These are just a few of the many things I tried without any success.
The missing lines/walls will change location with different settings.
First screen shot below shows missing vertical walls.
Second one shows similar to the original post.
Posted: Tue Feb 24, 2026 12:55 pm
by PatrickLevesque
Merci pour votre aide.
J'avais, moi aussi, fait un essai dans différentes tailles et postures, mair toujours des petits manques !
C'est curieux, car en effet l'affichage dans S3D est correct.
Posted: Mon Mar 16, 2026 2:42 pm
by PatrickLevesque
Pas de réponse de S3D ?
Posted: Tue Apr 14, 2026 7:04 am
by PatrickLevesque
Toujours pas de réponse de S3D ?
Posted: Tue Apr 14, 2026 7:32 am
by ampster
I'm not going to say this place is dead but you may have better luck contacting S3D's support thru their main website. I was able to get immediate assistance over there.
HTH for everybody still using S3D.
Posted: Tue Apr 14, 2026 1:21 pm
by PatrickLevesque
Merci pour votre conseil.
