Simply3d is slow at startup
Posted: Wed May 20, 2015 6:29 am
by pallemar
it sometimes take over 10 min before the program is ready.
any reason why?
Re: Simply3d is slow at startup
Posted: Thu May 21, 2015 5:44 am
by JoeJ
I've literally never had it take more than 1-2 seconds to open, so no idea. Maybe your anti-virus is scanning it every time it opens. I used to have an AV that did this, and it made me wait minutes before a program could open, as it had to check it out first. The software also restores your previous work when it opens, so it's possible you could have some giant model that the software has to reload when it opens, but even that should only take a few seconds.
Another possibility is that you're running out of system resources which just slows everything down. What type of computer specs do you have?
Posted: Sun Oct 02, 2016 3:13 pm
by Thump2010
This is happening to me now, nothing changed, machine is the same, I am not running anything else, very powerful PC but now it takes 8-10 minutes to start
Posted: Tue Oct 04, 2016 7:58 am
Thump2010 wrote:This is happening to me now, nothing changed, machine is the same, I am not running anything else, very powerful PC but now it takes 8-10 minutes to start
Check and make sure your internet connection is working and that there's no AV blocking it or scanning the software.
Posted: Thu May 18, 2017 10:20 am
by carlbeck
This is also a problem I have. Also: When it finally loads; and I import an stl file, it shows "Not Responding": and takes a long time to finally import that file. Then when I click "Prepare to Print"; it again shows "Not Responding" for a long time before it finally shows up again. This also happens when I save it to my SD Card. I have sent 2 e-mails to Support and so far have not had a reply. I believe there is a bug in their software and they don't have a fix for it. If it is a bug, I wish they would inform us.
