Controlling Raft Speed?
Posted: Wed May 20, 2015 10:13 am
by mitchfx
Is there a way to directly control the speed of the RAFT creation? None of the available speed settings (other default printing speed, which also controls infill speed) seem to affect it?
Re: Controlling Raft Speed?
Posted: Wed May 20, 2015 3:28 pm
by KeyboardWarrior
Your first layer speed % under the Layer tab will affect the first layer of your raft (probably the most important layer).
Posted: Thu May 21, 2015 1:36 pm
by mitchfx
Yes, that I was able to figure out. However I'd like to speed up subsequent raft layers to reduce print time. They are usually unnecessarily slow when my default print speed is set to 30mm/sec for example. Thanks!
Posted: Thu May 28, 2015 4:17 pm
by DarthRevan
you could use a separate process. just remember to account for the height of the raft when beginning the second process.
This may be of some help, if you try to go this route.
Posted: Tue Aug 16, 2016 6:27 pm
by InoTek3D
I am wanting to do this same thing. Has anyone else figured out how to do this.
Even with the 2 separate processes this doesn't work probably because the software still sees the "1st" layer as the raft layer for some reason. It doesn't see the 1st layer of the 2nd process as the 1st layer of the part so it ignores the 1st layer settings.
I have found that I get my best finish on ABS parts by printing 2-3 PLA raft layers and then Printing the ABS on top of that. It sticks well and doesn't warp at all, and once cool, the separate very easily. The only problem is that the raft layers are printing very slow and take a long time on larger prints. I would really like to print the 1st raft layer at 70% speed, and the rest at full speed. Then Slow down for the 1st layer of ABS, then Ramp back up to full speed for the rest of the print. I just can't get this software to do this though.
Seems like there should be a way.
Posted: Wed Aug 17, 2016 9:22 am
by DarthRevan
The first layer speed setting should be applied to the first layer of the raft. Have you tried bumping that up to 70%?
Posted: Fri Feb 24, 2017 7:37 am
by step3d
I'd like to increase the speed of the layers of raft above the first layer too.
Posted: Tue Apr 18, 2017 7:38 am
by DarthRevan
You can write a REPLACE command that takes the speed you're seeing for the existing raft layers above the first and replaces it with the speed you are wishing to use instead. The ayers of the raft above the first should consistently be printed at the same speed so you shouldn't need to alter this replace command all too often. This is assuming you don't regularly modify the default speed settings in the "Other" tab.
More on replace commands: viewtopic.php?f=8&t=1959
More on finding the specific speed setting inside the G1 Commands used by Simplify3D: https://www.simplify3d.com/support/arti ... torial/#G1
