Infill Extrusion Width problem
Posted: Thu May 28, 2015 2:20 am
by Carlos
Hello,
I have a problem with the Infill Extrusion Width. Am I right that it controls both, the extrusion width of the top / bottom infill layer and as well the infill between the shells?
I have the problem that when I set the Infill Extrusion Width to about 120% my top and bottom layers will look perfectly smooth but my infill is not very strong since the strings don’t bond to each other sufficiently. On the other hand if I set the value to 200% the Infill will be very strong but my top and bottom layer get a very rough surface since there is too much extrusion.
Is there an option to control the extrusion width of the top / bottom infill and the normal infill separately? Or will there be an option in the future?
Is anyone experiencing a similiar problem?
Re: Infill Extrusion Width problem
Posted: Mon Jun 15, 2015 1:31 pm
by DarthRevan
No, The infill extrusion width % setting does not affect solid layers. (top or bottom) This can be seen in the preview window fairly clearly.
Infill extrusion width set to 200%, Solid layer printed at normal extrusion width
Your bottom layers can be adjusted from the first layer settings area on the layer tab.
First Layer Settings. I find that increasing width and decreasing speed helps here.
from layer 2 and up any solid layers are printed with the base printing settings. I've found that sometimes I get a smoother surface if I slow down my print speed. now you of course probably don't want to do this for your whole entire print, and neither do I. I use a separate process for my top solid layers, and use a lower Default Printing Speed.
Also, if you need it, here is info on Printing with multiple processes
