What happened to randomizing infill in 3.0?
Posted: Wed Jun 24, 2015 12:58 am
by dodgersfan24
I noticed its not an option to check mark anymore?
Re: What happened to randomizing infill in 3.0?
Posted: Wed Jul 08, 2015 12:35 pm
by Memnarch1113
I think it wasn't widely used, so it got removed from the software.
Posted: Wed Jul 08, 2015 3:59 pm
by ashleywebster
It's too bad. I used it. It was a good way, when working with translucent materials, to make the infill pattern not so visible from the outside.
Posted: Wed Jul 08, 2015 8:05 pm
by jimc
it not really a big deal and you can mimic the effect by just setting half dozen or so infill angles and make sure the print infill on every layer is unchecked..
Posted: Wed Jul 08, 2015 8:35 pm
by bot
That seems like a silly attitude to have. I used it all the time for similar reasons to Ashley.
Also, the ability to alter the angle of external rectilinear infill was removed...
Posted: Wed Jul 08, 2015 10:30 pm
by jimc
what i am saying is you can get basically the same thing by just setting up a bunch of infill angles.
Posted: Sat Jul 11, 2015 11:58 am
by GoffyOne
I have been using that all the time. wouldn't it be easy to add it back in or has the code for generating the infill totally redone?
seams strange to remove a feature.
Posted: Sat Jul 11, 2015 9:05 pm
by jimc
I am just assuming here but i would bet that it was removed because until this thread i have never heard of anyone who used it so s3d prob figured the same and for new users it caused weak infill issues until they figured out to turn that function off. I just see that option as a big load of support calls so better off removed.
Posted: Sun Jul 12, 2015 1:07 am
by mitchfx
Yeah, I also used it often for translucent materials to camouflage the infill appearance. Good to know there is a way to recreate it manually, but a drop down option would be great to have again for ease of use.
