Parser error with accented characters in the file name
Posted: Mon Jun 29, 2015 4:57 pm
by iPa64
I have stored a factory file that include parts with accented characters in the file name (éèâë...).
When I have used load factory file feature, I got an error something like "Parser error...."
Then the name in the object list was displayed with some strange characters.
After that the biggest issue was very strange behavior from the slicer, 5 bottoms layers instead of 3, some missing other, ect...
I have tried many ways to get back a correct behavior but the only thing working was to setup a new machine profile from the wizard.
Re: Parser error with accented characters in the file name
Posted: Tue Jun 30, 2015 7:56 am
by JoeJ
Can you attach a factory file with the odd characters?
Posted: Tue Jun 30, 2015 12:47 pm
by iPa64
The exact error message is:
Failed to parse xml file
Encountered incorrectely encoded content
Maybe strange slicer behavior was not caused by this issue.
Because today I still get parse error but no issue with the slicer.
Posted: Tue Jun 30, 2015 2:42 pm
by DarthRevan
The special characters present in the factory file throw an xml parse error for me, too.
XML Parsing Error Message
Aftermath of XML Parse Error
If you rename the models, save another factory file, and import it, does it still give you a parse error?
PS: slicing seems fine on my end.
Posted: Tue Jun 30, 2015 3:47 pm
by iPa64
If I rename files, I don't get error anymore
Posted: Tue Jun 30, 2015 4:07 pm
by iPa64
About slicing behavior:
I've load again the factory file with files names content odds characters.
Prepare to print -> all are ok
Make some modifications in the Process1
- First layer from 90% to 100%
- Skirt outlines from 8 to 10
- primary extruded from 240 to 235
Then all goes wrong, slice with strange behavior!
And even if I reload the factory files slice behaviors are still here.
Posted: Tue Jun 30, 2015 4:10 pm
by DarthRevan
iPa64 wrote:About slicing behavior:
Safe to say we should avoid special characters in file names for the time being.
Posted: Tue Jun 30, 2015 4:23 pm
by iPa64
Yes agree with you
Posted: Wed Mar 01, 2017 4:51 am
by Z-Axis3D
Also seen the parser message when naming my profile with µ micron character. Haven't seen any issue with slicing behaviour. Just posting here for the record or anyone searching. Maybe the characters should be disallowed at the input stage.
Posted: Thu Mar 02, 2017 4:09 am
by horst.w
I have no problems with the german "Umlaute" in S3D but my printer do not accept them. I can choice the file on the display but nothing happens after this.
If I rename the file, all is well done.
regards
horst.w, GER
