3.0 Issues
Posted: Fri Jul 10, 2015 2:44 pm
Hey guys, Loving the 3.0 update so far. biggest win having the retract while wiping, perimeter avoidance with a variable, the infill, color coding... its all wonderous.
However there are a few things that have made me furious over the last few days. I work at 2 different 3d printing companies in Michigan, and own 5 printers at home. All in all i have a need to operate 8+ different models of printers in just about every material out there... simplify is running on OS X for more background, now onto the issues:
1. this has KILLED my productivity. adding new printers from the configuration assistant, awkward but ill bite, gets them out of the way when adding new profiles. as soon as I added a new printer, it WIPES all of my 15+ profiles, and are unrecoverable. I am not the type to want to backup my profiles, and re-open profiles upon opening simplify3d to print. This should at least WARN the user that everything you've tweaked will be deleted with no recovery unless you've backed your factory file....
2. I am sure you are aware, but perhaps in the midst of dual extrusion wizarding, when you go to print, it auto selects all of the profiles. I don't know how this made it into the release.... its the FIRST thing myself and others have scoffed at upon printing... just not user friendly.
mostly my issues are with the profile system. Its clunky, likes to delete everything without warning, and expects you to print on 6 printers at different materials and layer height at once by default.
I apologize if I sounded harsh here, I understand you all have probably had some late nights with little sleep in-between, but these issues have made my job difficult and downright frustrating... profiles are the most valuable functional settings of simplify3d, and reseting them every other day feels bad man.
