[SOLVED] Avoid bridging infill when support enabled
Posted: Mon Jul 20, 2015 10:03 am
I wondered if it is possible to avoid the bridging infill when support is used.
My problem is, when I have a very narrow piece which has to be supported, there is still the 90° infill for the first layer on the support structure. It would be nice if it is possible to deactivate the bridge infill pattern if support is used, since the 90° can sometimes not fill out the whole piece so I have very long slots on print (see image).
Playing around with the extrusion width doesn't help because the I got problems on an other part of the peace. As well increasing the outline overlap doesn't help.
