Ultimaker 2 Dual extrusion Profile
Posted: Tue Jul 21, 2015 5:47 pm
by KevinMakes
Hello, I was told when I purchased this software that it would contain support for the ultimaker 2 Dual Extrusion. I attempted to use the standard profile..."Ultimaker 2" but it didn't support Dual extrusion, and most recently I attempted to make a custom printer profile and that didn't support dual extrusion. Is there any way to actually use this software to support dual extrusion with the ultimaker 2?
Re: Ultimaker 2 Dual extrusion Profile
Posted: Thu Aug 20, 2015 7:50 am
by UltiArjan
You need to set it up manually.
Here's a sample factory file I use on my UM2.
https://www.dropbox.com/s/413d76tw66j0a ... ctory?dl=0
I use it in my dual head setup (
https://www.youmagine.com/designs/dual-head-ultimaker2) so
YOU WILL NEED TO REMOVE the toolhead change script in the script tab !!! And you'll need to change the XY g-code offset, and I may be forgetting something
Use at your own risk
