Dual extrusion ; Ooze shield / Prime tower.
Posted: Thu Aug 20, 2015 8:42 am
I noticed that even though you can allocate specific extruders, offset mm's and position to the prime tower and the ooze shield, it fails to build separate shields or towers for the both extruders.
I would really like to have this, as it prevents the smearing between 2 colors when you use 2 separate nozzles.
I would be even better if the ooze shield could be build out of 2 parts (left/right) each for 1 nozzle.
Of-course this means you force to use both extruders on every layer, but this how I like it...
FYI this is my setup; Ultimaker2 with magnetic changing dual head (https://www.youmagine.com/designs/dual-head-ultimaker2)
