Gap between infill and perimiter
Posted: Mon Aug 31, 2015 2:25 am
Hey everyone,
I recently changed extruders to a 1.2mm E3D volcano setup. Decided to start up S3D again and give it a go as im not having much luck with slic3r and off the bat S3D gave me a better print for a calibration cube. However im still having big issues with gaps between the infill and perimeters and the perimeter walls also seeming like they have a gap.
This is what I started with on the first print.
Printed with 1.2mm nozzle
-.9 layer height
-1.2mm extrusion width
-200 degrees celsius
-extrusion multiplier of .9
-speed 1800mm/min, outline underspeed 50%, solid infill underpeed 80%
-3 layers top and bottom
-2 perimeters
-infill 20%
-outline overlap 15%
-infill extrusion width 100%
-min infill length 5mm
Since that point I have gotten it a bit better by changing. you can notice in the bottom left of the second image a hole, these holes lead almost all the way through the cube as if when the printer goes to any corner it always leaves a gap on the turn.
-205 degrees celsius from 200
-outline overlap 70%
-min infill length .1mm (I did this thinking that it was purposely skipping the corners because of thsi setting)
Would love to hear peoples recommendations on what todo to fix this,
-.9 layer height
-2 perimeters
-infill 20%
