Rafts
Posted: Wed Sep 09, 2015 11:53 pm
by erniehatt
I have just printed a fairly large model and decided to use a raft, but I cannot get the model to release from the Raft.
Probably due to some setting I have made, what setting are a good starting point. Also where can I locate the Brim settings. :? Ernie
Re: Rafts
Posted: Thu Sep 10, 2015 10:11 am
by JoeJ
Increase the raft "separation distance". Larger values will make the raft separate easier.
Re: Rafts
Posted: Thu Sep 10, 2015 5:54 pm
by erniehatt
Thanks Joel
Re: Rafts
Posted: Thu Sep 10, 2015 11:39 pm
by KC_703
Set the "Skirt Offset from the Part" to 0.00 for a Brim.
Re: Rafts
Posted: Fri Sep 11, 2015 6:36 am
by JoeJ
Yup, a brim would be a good option too. If you're new to this, there's a great tutorial about all of these options here: https://www.simplify3d.com/support/tuto ... and-brims/
Re: Rafts
Posted: Fri Sep 11, 2015 10:04 pm
by magicwiser
JoeJ wrote:Increase the raft "separation distance". Larger values will make the raft separate easier.
Be careful though because if your value is too big it will warp and separate mid print. After a lot of tinkering, 0.20 seems to work well for me. However, if it is going to be a large print sometimes I will lower it a bit just to make sure it stays together.
