Small Details Get Lost?
Posted: Mon Oct 05, 2015 7:38 pm
by DoDirty
I'm trying to print a clay stamp but when I slice all the detail is lost. S3D just fills everything in. The raised portion is about 1mm thick and sticks up 5mm from the cube surface. Sli3r picks up the detail, so I'm sure its some setting I'm missing. Using .4 nozzle at .2 height with 2 perimeter and 4 top/bottom layers and 40% infill. What am I missing? Thanks.
Re: Small Details Get Lost?
Posted: Tue Oct 06, 2015 7:18 am
by JoeJ
If it's 1mm thick then it should print fine. Can you post your factory file (file > save factory file)?
Posted: Wed Oct 07, 2015 9:01 pm
by DoDirty
Sorry for the delay, please find attached.
Posted: Thu Oct 08, 2015 6:57 am
by JoeJ
Go to Advanced tab and disable the "merge all outlines into single solid model" option
Posted: Thu Oct 08, 2015 7:58 am
by DoDirty
That was exactly it, I had forgot I enabled that for some vase printing. Thanks!
