brim feature not split between processes
Posted: Mon Oct 26, 2015 4:47 pm
by danielhenley
Often when printing multiple objects I want some to have a brim because they need some extra bed adhesion, yet other parts in the same print don't require a brim--including one would just add to cleanup.
S3D "should" be able to do this via it's multiple process feature, but it doesn't--the brim settings on the first process are always used by all parts regardless of what their brim is set to.
Expected: each part uses the brim setting from it's own process.
Re: brim feature not split between processes
Posted: Fri Dec 25, 2015 2:37 am
by MikeConnor821
+1
Posted: Fri Dec 25, 2015 6:29 am
I just did a quick test and had no problems printing 2 objects with 2 processes - one with a brim and one without. It seems to work fine for every test I do.
Do you have a factory file for your specific issue? Maybe it's just an easy setup option you need to adjust
Posted: Fri Dec 25, 2015 10:59 am
by MikeConnor821
The top part is sliced correctly with a 3 layer, 44 outline brim. The bottom part is supposed to have a 1 layer, 2 outline skirt, 4mm out. Does the .factory file include the processing settings, etc?
Thanks and Happy Holidays,
mike
Posted: Sat Dec 26, 2015 5:48 am
Just separate the models bit more. If they are too close, the skirt for each one will get combined (and thus use the same settings). I just moved then an extra 10mm apart and then it worked.
