Everything is 64bits except the dynamically linked gpx program.
Code: Select all
j@laptop:/opt/Simplify3D-3.0.2$ file * | grep ELF
gpx: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.24, BuildID[sha1]=9aec7d91d1fe815402bece0ec4853ea46ff95dc6, not stripped
libicudata.so.52: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=854130c23d7cec9d0a7f39ba93a5898ef5b37414, not stripped
libicui18n.so.52: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=eb2cdcf69cc5bae813e83730465948e382a8de49, not stripped
libicuuc.so.52: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=7e79aebf7a79aae45338128c66e62f1f648b3718, not stripped
libInterface.so: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, stripped
libQt5Concurrent.so.5: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=ecae7815584ba35c721dc0025b6f58c52dcc0c19, stripped
libQt5Core.so.5: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked (uses shared libs), BuildID[sha1]=9dc1d05efaa8a8c59e7e7412e95980fbd6b33150, stripped
libQt5DBus.so.5: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=38b39f95d6da69d1837ba9d710ec108cc8bca3a4, stripped
libQt5Gui.so.5: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=d0c6f207b870f9b1d2325922eeee235beded0b8d, stripped
libQt5Network.so.5: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=c87ea3e437df4391791cec8df04fd3a19f08f584, stripped
libQt5OpenGL.so.5: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=39fcede6c8c0d3c80397eead57153721dc85a3bb, stripped
libQt5Script.so.5: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=2e1a09017b4d039086872afe1090bac680f8453f, stripped
libQt5SerialPort.so.5: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=ea8920e720c4c94f7adc970fa5960dd0f12fe2c4, stripped
libQt5Widgets.so.5: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=e07deef5a6a404fae6342a098ce47b8766205060, stripped
libquazip.so.1: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=50b2c51b63a82d4fcfc814da2b38ee4bd78a4a86, not stripped
libusb-1.0.so: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=5ec42001275603a7c42ac8f6766f5a34a1f30870, not stripped
libz.so: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=c74d8ff2dd9c3defc129535eb4bd6cfa309168cd, not stripped
PostInstaller: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.24, BuildID[sha1]=c272244c24ddf770b5f6655f19f0c582b60bcd33, stripped
PostUninstaller: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.24, BuildID[sha1]=ccee0a9a94e91e2398c5a26596596b742e1abf38, stripped
Simplify3D: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.24, BuildID[sha1]=f2e7d97f943d8b7efdf957bfffe03c3fefbe28b5, stripped
This program requires that you have the 32bit libc.so and libm.so.
You probably already had these 2 installed as a dependency of some other package you had installed.
