I have the option to create an x3g file checked and all the configuration settings seem to be correct.
But it doesn't seem to be generating any x3g files.
Any suggestions?
I'm not sure why you would say that? I have the 64-bit version of S3D installed and it works fine. There are no 32-bit libraries anywhere.giantpune wrote:Are you using 64 bit Linux? They have a bug where the program to create x3g files is a separate 32 bit dynamically linked program. Without the necessary 32bit libraries installed, Simplify3D cannot create xg3 files.
Everything is 64bits except the dynamically linked gpx program.JoeJ wrote:I have the 64-bit version of S3D installed and it works fine. There are no 32-bit libraries anywhere.
j@laptop:/opt/Simplify3D-3.0.2$ file * | grep ELF
gpx: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.24, BuildID[sha1]=9aec7d91d1fe815402bece0ec4853ea46ff95dc6, not stripped
libicudata.so.52: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=854130c23d7cec9d0a7f39ba93a5898ef5b37414, not stripped
libicui18n.so.52: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=eb2cdcf69cc5bae813e83730465948e382a8de49, not stripped
libicuuc.so.52: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=7e79aebf7a79aae45338128c66e62f1f648b3718, not stripped
libInterface.so: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, stripped
libQt5Concurrent.so.5: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=ecae7815584ba35c721dc0025b6f58c52dcc0c19, stripped
libQt5Core.so.5: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked (uses shared libs), BuildID[sha1]=9dc1d05efaa8a8c59e7e7412e95980fbd6b33150, stripped
libQt5DBus.so.5: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=38b39f95d6da69d1837ba9d710ec108cc8bca3a4, stripped
libQt5Gui.so.5: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=d0c6f207b870f9b1d2325922eeee235beded0b8d, stripped
libQt5Network.so.5: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=c87ea3e437df4391791cec8df04fd3a19f08f584, stripped
libQt5OpenGL.so.5: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=39fcede6c8c0d3c80397eead57153721dc85a3bb, stripped
libQt5Script.so.5: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=2e1a09017b4d039086872afe1090bac680f8453f, stripped
libQt5SerialPort.so.5: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=ea8920e720c4c94f7adc970fa5960dd0f12fe2c4, stripped
libQt5Widgets.so.5: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=e07deef5a6a404fae6342a098ce47b8766205060, stripped
libquazip.so.1: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=50b2c51b63a82d4fcfc814da2b38ee4bd78a4a86, not stripped
libusb-1.0.so: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=5ec42001275603a7c42ac8f6766f5a34a1f30870, not stripped
libz.so: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=c74d8ff2dd9c3defc129535eb4bd6cfa309168cd, not stripped
PostInstaller: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.24, BuildID[sha1]=c272244c24ddf770b5f6655f19f0c582b60bcd33, stripped
PostUninstaller: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.24, BuildID[sha1]=ccee0a9a94e91e2398c5a26596596b742e1abf38, stripped
Simplify3D: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.24, BuildID[sha1]=f2e7d97f943d8b7efdf957bfffe03c3fefbe28b5, stripped
j@laptop:/opt/Simplify3D-3.0.2$ readelf -a gpx | grep NEEDED
0x00000001 (NEEDED) Shared library: [libm.so.6]
0x00000001 (NEEDED) Shared library: [libc.so.6]
Go re-download the software and do your tests again. All of the files in my installation directory are 64-bit, including the gpx file you mentioned. I do NOT have any 32-bit libraries installed, and I don't need them either. All of the files in the current 3.0.2 installer from the website are fine. I just re-downloaded and re-installed just to be sure.giantpune wrote:This program requires that you have the 32bit libc.so and libm.so.
You probably already had these 2 installed as a dependency of some other package you had installed.
