Started using LEFT extruder....small issue
Posted: Sat Dec 12, 2015 4:44 pm
I have a Flash Forge Creator Pro Clone.
Since I got it I had been printing only with the right extruder.
Yesterday I decided to start printing with the Left extruder for two reasons... to make sure it worked before the warranty runs out and to print with a different color filament.
Basically it does ok but there is a small issue.
On every print with the Left extruder there seem to be small (5mm) sections of filament deposited randomly on the print.
This is usually on the first two layers, on an outline.
Sometimes this bit of excess filament will get in the way so that when the head comes back around and hits it, it lifts a part of the first layer off, and ruins the print. It's like a little unexpected "squirt" of filament.
I use the exact same file and the exact same settings as on the right extruder and simply change all the settings in the Process to use the Left extruder.
This never happens with the right extruder. Any idea what could cause this and the cure?
