Model won't drop to table
Posted: Thu Dec 24, 2015 11:46 am
by RomeFallsAgain
First time I've had this issue.
The only way I can get the model flat on the table is manually.
"Drop Model to Table" leaves the model about 2mm above the table.
Any suggestions?
Re: Model won't drop to table
Posted: Thu Dec 24, 2015 12:08 pm
There must be something that's not readily visible in the model that exists approx. 2mm below where you think the bottom is.
Post your factory file so someone can take a look at it for you...
Posted: Thu Dec 24, 2015 12:21 pm
by RomeFallsAgain
When I looked at it again, it appears the model is on the grid, but the grid appears to be slightly above the platform.
This started when I set up a configuration for dual extrusion and added a machine profile under --> Help --> Configuration Assistant
So maybe it's just something I'm not used to?
Posted: Thu Dec 24, 2015 5:23 pm
by horst.w
The best to prove that, is the Print-PreView .
Therefore check BRIM with a very small OffSetFromPart, e.g. 0.05 mm
Is all correct, BRIM follows the outside-conture of the object very exactly. Is there a gap between object and grid (table) BRIM will subvert the object there.
I have made an example, have a look to attachment.
Stand gerade.jpg (9.89 KiB) Viewed 1688 times
Stand schief.jpg (5.59 KiB) Viewed 1688 times
Brim schief.jpg (6.09 KiB) Viewed 1688 times
H.
