Different settings for the bottom and top layer
Posted: Thu Dec 31, 2015 1:32 pm
by donpedro
Hi , may I can use different settings for the top and bottom layer ? How to do this ? I mean I wish I can set different last layer above the top layer , not just the top that ends the piece to print it when the top layer is placed at different levels, thanks in advance .
Re: Different settings for the bottom and top layer
Posted: Fri Jan 01, 2016 6:28 am
What setting are you looking to change? I usually print all of my top layers slower for good quality, so there's options for that
Posted: Fri Jan 01, 2016 3:54 pm
by donpedro
Hello
I would like bottom layer to print them at high speed , and the top layer low speed without making multiple processes for the same song , I did this but only for the final coat , I find it very difficult to do that if I have a track the top floor has several layers , and from what I saw can not use different settings for bottom and top speed layer
For instance what speed settings for the top layer using ?
Posted: Sat Jan 02, 2016 6:07 am
You can adjust the "solid infill underspeed" setting on the Other tab. That will decrease the speed for the top and bottom solid layers. I use this a lot and it works great and definitely improves the print quality
