Simplify3D When can support D-Force?
Posted: Wed Jan 27, 2016 6:52 am
by intorner
Hello~
D-Force have 2 Extruder ,How to set the distance between them ?
I need you help~~thank's~
Re: Simplify3D When can support D-Force?
Posted: Thu Jan 28, 2016 4:27 am
That printer is already compatible. It uses standard gcode, so it will already work with S3D, Cura, Repetier, etc (the product page confirms this as well).
So just go to Help > Configuration Assistant, select Other, then follow the on-screen prompts. I've setup my delta this way and it worked fine.
