Bridging Confusion
Posted: Sun Mar 06, 2016 6:38 pm
by czucker
Hi Folks,
I am experimenting with bridging and suspect that I not thinking about it properly.
I have a cube that I am printing with one perimeter (.8mm nozzle), 0% infill and some top layers. I would expect that the top layers would bridge, but when I slice the initial top layers show up as solid layers. . . .
Am I doing something wrong?
Thanks,
Chris
Re: Bridging Confusion
Posted: Mon Mar 07, 2016 6:12 am
It's only a bridge if there is nothing below that part of your 3D model. It doesn't matter if you use 0% or 50% infill, it is based on the model itself.
Maybe you should hollow out your model instead of using 0% infill. That way they would actually be real bridges.
Posted: Mon Mar 07, 2016 11:15 am
by czucker
Thanks for the info.
I'm still not completely sure I understand. Take the attached factory file for example. This is a hollow object, with 0 bottom, and the top layers still are not bridging. . . .
https://drive.google.com/file/d/0B5G4LM ... sp=sharing
Posted: Tue Mar 08, 2016 7:21 am
That model bridges fine for me... Switch your preview to "Feature Type" coloring, so that it's easier to see. But frankly, it's a circle. So it doesn't really matter if your bridging or not since there really isn't an ideal direction to print in. All directions would be identical ;)
If you're still having trouble, post your factory file (File > Save Factory File)
