reversed model
Posted: Wed May 04, 2016 4:07 am
by erniehatt
the model I am trying to print shows correctly in S3D but when saved to gcode it prints back to front, what is happening here.
How can I fix it
Re: reversed model
Posted: Wed May 04, 2016 5:19 am
by andrewk72
What printer are you using? Did you make your own profile for it?
There's settings for flipping the XYZ axes and changing the axis directions, but you shouldn't need to adjust those if you are using one of the built-in profiles.
Re: reversed model
Posted: Wed May 04, 2016 5:26 am
by erniehatt
I am using an reprap i3.
This has never happened before with other prints.
It shows it as being correct in the preview, but when I slice it it changes.
Re: reversed model
Posted: Fri May 06, 2016 3:38 pm
If it's happening when you slice, then it would probably be best if you attached your factory file since that should help others reproduce it
