S3D Machine Control Issue with M2
Posted: Wed May 18, 2016 8:28 pm
by scampa
I've encountered an issue tonight with S3d's Machine Control Panel and my M2...This previously worked, and I'm not sure what is wrong...
The Machine control panel connects to my Makergear M2, however I am unable to control it. I cannot use the controls. I cannot turn on the extruders, I'm unable to open the SD card dialog for printing...
In the communication dialog I see a stream of SENT: M105 periodically...
Here is what I am seeing...
Attempting connection at \\.\COM3...
RECEIVED: start
Connected to machine!
RECEIVED: echo: External Reset
SENT: T0
RECEIVED: Marlin 1.0.0
RECEIVED: echo: Last Updated: Mar 5 2016 12:40:58 | Author: (none, default config)
RECEIVED: Compiled: Mar 5 2016
RECEIVED: echo: Free Memory: 4141 PlannerBufferBytes: 1232
RECEIVED: echo:Hardcoded Default Settings Loaded
RECEIVED: echo:Steps per unit:
Steps per unit:
RECEIVED: echo: M92 X88.88 Y88.88 Z400.00 E471.50
RECEIVED: echo:Maximum feedrates (mm/s):
RECEIVED: echo: M203 X500.00 Y500.00 Z25.00 E25.00
RECEIVED: echo:Maximum Acceleration (mm/s2):
RECEIVED: echo: M201 X4000 Y4000 Z100 E10000
RECEIVED: echo:Acceleration: S=acceleration, T=retract acceleration
RECEIVED: echo: M204 S2000.00 T3000.00
RECEIVED: echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
RECEIVED: echo: M205 S0.00 T0.00 B20000 X8.00 Z0.40 E5.00
RECEIVED: echo:Home offset (mm):
Home offset (mm):
RECEIVED: echo: M206 X0.00 Y0.00 Z0.00
RECEIVED: echo:PID settings:
PID settings:
RECEIVED: echo: M301 P25.89 I1.94 D86.53
RECEIVED: echo:SD card ok
SENT: M105
SENT: M105
SENT: M105
SENT: M105
SENT: M105
SENT: M105
SENT: M105
SENT: M105
SENT: M105
SENT: M105
SENT: M105
SENT: M105
Any help would be appreciated!!
Thank you!!
Re: S3D Machine Control Issue with M2
Posted: Fri May 20, 2016 5:28 pm
by scampa
As it turns out the USB cable seems to have gone bad! I replaced the USB cable and everything is running again!
