Missing some layers
Posted: Sun May 22, 2016 10:05 am
by Budi67
Hello
I have a strange problem !!
It missing some layers.
It's the first time that it happens
I have already spent it on https://netfabb.azurewebsites.net/
Any Idéa ?
A big thanks
Budi67
Re: Missing some layers
Posted: Sun May 22, 2016 10:39 am
by Budi67
I have tried with "Merge all oultines into a single solid layer" and it's ok !!
But i lost the holes at the end of the canonn
Posted: Sun May 22, 2016 11:57 am
Can you attach your factory file to a post so we can take a look at your setup, etc.
File==>Save factory file.
Posted: Sun May 22, 2016 12:11 pm
by Budi67
Here's the file ==>
project.factory
(2.55 KiB) Downloaded 305 times
Posted: Sun May 22, 2016 1:26 pm
We need the factory file WITH the model.
Posted: Sun May 22, 2016 1:57 pm
by Budi67
Oups, sorry :roll: :roll:
project.factory
(54.73 KiB) Downloaded 324 times
Posted: Sun May 22, 2016 2:13 pm
Wall thickness is your problem.
The wall thickness of the barrel in the area where it misses out the layers is below the width of a single extrusion. You'll need to reduce the diameter of the tapered bore at the end of the barrel so the wall thickness is increased.
Posted: Sun May 22, 2016 2:19 pm
by Budi67
Thank for your answer.
If the translator makes his work, you recommand to modify the file ?
If yes, it's a commercial STL
