Skipped/weak/under extrude sections at the starting points
Posted: Tue Jun 14, 2016 10:57 pm
by niamleeson
I'm getting some thin lines at the starting points of each layer in some of the parts. almost 1/3 of a section of the print has this problem. Would you please take a look at the factory file and see what is wrong?
Re: Skipped/weak/under extrude sections at the starting poin
Posted: Wed Jun 15, 2016 8:30 am
It would probably help more if you posted a picture of your actual print. But from your description, I'm guessing you just need to increase your extra restart distance setting
Posted: Wed Jun 15, 2016 7:25 pm
by niamleeson
CompoundCarl wrote:It would probably help more if you posted a picture of your actual print. But from your description, I'm guessing you just need to increase your extra restart distance setting
Here's a picture of the symptom:
Posted: Thu Jun 16, 2016 6:17 am
Try increasing the extra restart distance to +0.1 or +0.2mm. You may also want to try disabling wiping to see if that helps.
