Perimeter: 2x Thickness?
Posted: Wed Jun 15, 2016 9:27 am
by caylan
Usually I print 2 or 3 perimeters. These are printed at the same extrusion width as "normal." Is there a setting to adjust the perimeter width so I can print 2x thickness and halve the number of perimeters?
Re: Perimeter: 2x Thickness?
Posted: Thu Jun 16, 2016 6:12 am
Do you really mean width?? I would think printing the perimeters at twice the normal width would be a very bad thing. You usually want to print with the smallest width you can on your perimeters, since that has a big impact on the detail and accuracy of your outer surface.
Posted: Thu Jun 16, 2016 2:30 pm
by caylan
CompoundCarl wrote:Do you really mean width?? I would think printing the perimeters at twice the normal width would be a very bad thing. You usually want to print with the smallest width you can on your perimeters, since that has a big impact on the detail and accuracy of your outer surface.
Yes, I meant width. You're right about detail, but in my case the shape I'm printing (cylindrical) would not benefit from narrower widths. Interesting point, though.
Posted: Thu Jun 16, 2016 2:32 pm
by zemlin
I think you'd want to use a larger nozzle diameter to achieve the twice the extrusion width. I use a larger nozzle for heavier prints so I can go wider and thicker to save print time.
