Part sags in on itself
Posted: Tue Sep 27, 2016 11:16 pm
by technobabble
Hello,
I am trying to print out a lid for a part. I've been printing it like a bowl (see picture), however a consistent ridge along the outer part forms. It is about the same width around, which means that the part isn't shifting. Has anybody had this problem and solved it?
Material: ABS, black
Printer: FF Creator X with glass bed
Profile:
infill: 20%
support: none
outline overlap: 20%
Infill extrusion width: 102%
Cooling fan on
build chamber on (cardboard box)
Re: Part sags in on itself
Posted: Wed Sep 28, 2016 8:50 am
by ftdesigns
In regards to that ridge, do you have an image of the 3D model we can see?
The mark on the bottom of the bowl is the extruder nozzle moving to close to that layer and melting the plastic. You can't do anything about that unless you somehow change the toolpath of the extruder.
Posted: Wed Sep 28, 2016 9:10 am
by wirlybird
If the ridge is to the bottom when printing then I would say it needs some supports since it looks to be printing in air. Maybe the extrusion multiplier is a bit high also?
Posted: Wed Sep 28, 2016 1:09 pm
by technobabble
wirlybird wrote:If the ridge is to the bottom when printing then I would say it needs some supports since it looks to be printing in air. Maybe the extrusion multiplier is a bit high also?
When I added support (22% regular, 35% dense), it generated supports, but they didn't go as high as the ridge. I'm not sure if supports alone will work.
I tried printing it like an upside down bowl, and the ridge went away.
The extrusion multiplier does seem a tiny bit high (mm bumps where the head lifts off). Thanks for the suggestions.
Posted: Wed Sep 28, 2016 1:48 pm
by dorsai3d
FYI, the arch in your first image is most likely an impression from your second extruder as it travels over the already printed part.
Posted: Wed Sep 28, 2016 2:49 pm
For information, if you have this issue again you will need to add support manually.....which is quite easy to do. Try it now on this object so you get some practise....
Posted: Wed Sep 28, 2016 8:48 pm
by technobabble
I'll certainly look into it. Thanks Doug
