Page 1 of 2
X-Axis Jog Control on Creatr
Posted: Mon Jan 13, 2014 8:26 pm
by Outbound
Another bug I've noticed is that for some reason the X-axis jog control doesn't function properly for the left side increments. It will accept one input and all other left move commands will go ignored.
Anyone else experienced this?
Re: X-Axis Jog Control on Creatr
Posted: Mon Jan 13, 2014 10:25 pm
by Festus440
Doesn't work for me either. Except in my case hitting the left jog control moves the print head to the right. Not a big deal but does seem to be a bug. The old version did the same thing.
Posted: Thu Jan 16, 2014 7:04 am
by Arno_Millenaar
I also have a Creatr connected with S3D ver 2.0.1 and do not see the problems you have experienced on the Jog Controls. I have double checked and no problems what so ever.
As there are many problems possible with the serial interface and the drivers I would be tempted to believe that this is where you may need to start searching. For example I have hard wired the ground of my computer with the chassis of the Creatr and this seems to help a lot in preventing communication errors and stalls. Still I have made a number of extra modifications to the electronics (board) of the Creatr, including making a common ground within the chassis in order to prevent all types of unwanted ground-signal-noise I noticed on the signals. I also added a step-down-converter, providing a separate power to the board, instead of relying on the USB/computer to power the Creatr electronics.
Not sure you are able to 'improve' your Creatr as I have done, however as a active Creatr/S3D user I can only confirm that the problem is not within Simplify3D software.
Rgds,
Arno
Posted: Fri Jan 17, 2014 5:06 pm
by jimc
i checked this the other day as well and mine has always worked exactly as it should. i am running on a mac.
Posted: Fri Jan 17, 2014 10:59 pm
by Festus440
Okay I'm going to say at this point that it might be a firmware bug. (Not an expert here.) I'm using the original firmware.
The left jog control works fine until I turn on the heater for the left extruder. After that ALL of the left jog buttons move the print head about 10mm to the right.
I get the same result using Repetier host.
If I turn off the heater, disconnect and then reconnect it's okay until I turn the left heater on again.
Posted: Sun Jan 19, 2014 10:16 pm
by Outbound
Yeah, that seems about right Festus440.
Posted: Mon Jan 20, 2014 3:45 am
by Arno_Millenaar
See my posting on the http://creatrtips.freeforums.org/common ... -t128.html as what you experiencing is most likely not a firmware problem, however a noise problem on your USB signals and board caused by a common ground problem. This also explains why it happens more often when you have the heater on.
Rgds,
Arno
Posted: Mon Jan 20, 2014 1:35 pm
by Festus440
Arno,
Power supply noise due to grounding may be an issue.
However I would think if that was the case the problem would go away when the heaters are turned off. (I'll have to double check that this evening.)
Thanks.
Posted: Mon Jan 20, 2014 1:45 pm
by Arno_Millenaar
Festus440 wrote:Arno,
Thanks.
Just as an FYI, I am not aware of any past or current firmware issues in the Marlin code. I have been using several versions of the Marlin and never have seen anything that looks like your problem. Keep in mind that Creatr is using a 'modded' version of Marlin. As you can expect they do not always use the latest version, still to my knowledge I have not seen anything in the past updates on Marlin that would suggest it is a firmware problem.
Rgds, Arno
Posted: Mon Jan 20, 2014 10:34 pm
by Festus440
So a little more testing.
I printed a part and afterwards the left jog problem was there.
I hit disconnect in the software, turned the printer off, and unplugged the usb cable from the computer.
I waited 60 seconds, hooked everything back up and hit connect in Creater.
Without turning any heaters on the left jog problem was still occuring.
To get things working normally I had to restart Creater.
I did this more than once with the same results.
As I said before it's not just Creater.
It also doesn't always happen as soon as I turn the heaters on.
